purplespider Posted September 14, 2004 Share Posted September 14, 2004 For quite a while now when I go to http://www.download.com on my laptop it looks like this: http://www.pswd.biz/downloadcomproblem.gif - Nearly all the images do not load and the CSS stylesheet appears to not be loaded. The page loads perfectly on my PC so I did some investigating (here comes detective purplespider again!) I discovered that the images which did not load and the CSS stylesheet which didn't load were located at http://i.i.com.com which seems a strange address but I then worked out by going to http://www.com.com that cnet owns www.com.com. If I go to http://i.i.com.com it rather bizzarly points to the root dir of my Apache web sever which I have running. So does http://adlog.com.com which seems to be a subdomain that cnet uses for adverts. This happens in both Firefox, Mozilla and IE. I've tried turning the web server service off but then I just get a "The page cannot be displayed" when trying i.i.com.com So has anyone got any ideas why this is happening?? I can't figure it out!! Cheers James Quote Link to comment Share on other sites More sharing options...
MikeJ Posted September 14, 2004 Share Posted September 14, 2004 Sounds like you installed an adblocker, or changed your hosts file to block ads on your notebook. It's a fairly common practice to redefine ad serving hosts to point to your local machine so that ads don't display, and the behaviour you are seeing suggests that. Quote Link to comment Share on other sites More sharing options...
purplespider Posted September 15, 2004 Author Share Posted September 15, 2004 Ahh perfect, thanks Mike. I checked in my hosts file and those domains were listed, must have been put there by Webroot SpySweeper. Cheers James Quote Link to comment Share on other sites More sharing options...
