Hello. I have a 60gig hard drive that I partitioned into two 30's. I need to run WinMe on one part, and WinXP Pro on the other.
I alredy put WinME on the first Part, but I am trying to put WinXP on the other Part, but the computer wants to always start on the C: drive (Win ME).
How can I have this setup work for me? Is there any way to select when I start the computer which OS I want to run?
Thanks,
MJB
I cant promise this works in ME cause I use 2000 but in your Control Panel open the System Icon. Go to the Advanced tab and click the Startup and Recovery button at the bottom. Place a check in the box "Display a list of operating systems and you should be good to go. Let me know if ME isnt that way and I will see if I can find the right way.
