Hi!
I'm currently trying to add a contribution onto oscommerce that would let me integrate phpbb to it.. one of the instructions tells me to...
Perform the folowing command at .\catalog if on a unix shell :
ln -s includes/modules/phpbb2/templates/ templates
This creates a virtual folder to where templates are really and is important as allow to install other templates without any modifications.
If you dont have access to unix, it should be possible to implement using a the modwrite engine at .htaccess. Or just replicate the folder includes/modules/phpbb2/templates/ to /catalog/.
HOW DO I DO THIS?!?!
I've searched through the oscommerce forums with no luck and no one ever seems to answer my posts there, so I'm hoping that my host would help me out since we are family... Help a sister out!
Thanks in advance!
You'd need shell access to do that and since shared accounts on TCH have no shell access, you won't be able to do that directly. However, you can submit a help desk ticket (link at the top of the forums pages) and ask that the tech staff creates the link for you.
This should work without a ticket. Just copy everything in includes/modules/phpbb2/templates/ to /catalog/
