TEWF.com Posted June 13, 2004 Posted June 13, 2004 I'm trying to install Olate Download, but I keep getting this error. Im not too good with database stuff, can anyone help? This step installs the tables into your database and populates the dp.php file with the correct data needed to use Olate Download. This process may take a few moments. Progress Database Error: Access denied for user: '@localhost' to database 'tewfcom_data' Before installation can continue, you need to rectify the problem(s) indicated above. Click here to go back. Please enter your database details below. If you do not know these details, contact your web host. The installation will not create the database for you so ensure that it exists. Database Servername: Database Username: Database Password: Database Name: Table Prefix: Quote
TCH-Andy Posted June 13, 2004 Posted June 13, 2004 Hi, Welcome to the family You will need to create the database in cpanel (manage mysql) if you have not already done so - and make sure you add a user. From the error it looks as if the username is incorrect; Database Servername: localhost should be fine Database Username: tewfcom_user (if you defined it as user when you created it) Database Password: as you defined in cpanel - manage mysql Quote
