Queenie Posted November 13, 2002 Posted November 13, 2002 Hello, I just moved in serpensortia.net, which has all been fine and dandy, but I'm having some problems trying to set up a guestbook. I put up one at http://serpensortia.net/gbook which worked fine. Then I fiddled with some of the settings, and it stopped working. (When you try to post an entry, it just refreshes the entry page and doens't post anything.) So I set up another one at http://serpensortia.net/book and I left all the PHP coding as it was, and only changed a little bit of the layout. But that one has the same problem as the other one, even though I'm sure I haven't changed anything important. Any help much appricaited. Queenie Quote
mountaindew Posted November 13, 2002 Posted November 13, 2002 Sweet Layout on the Guestbook. I will take a look for you after lunch hour. I can tell you that the guestbook is the #1 complaint from users and Cpanel. It doesnt like any changes at all. I will update soon. Thanks Quote
