I like totalchoice very much. But even the $4 plan is too big for a some websites. I adminiser a few very small, very low-traffic websites which could all fit together into TCH's "Starter Plan" and still use only a fraction of the allocated diskspace and bandwidth. Ordering a $4 for each would be crazy. So I am looking for an honest and reliable host that allows hosting multiple domains on a single small plan. So far, I didn't find the ideal host. The ones that have the features and the plans I need are relatively new and I cannot find any reviews about them. Others are very expensive. And two hosts about which I did find good reviews never replied to my e-mails, and this isn't a good sign. Any recommendations?
Thanks.
This is an even more expensive solution, but might not be if you split the cost on all your sites...
Why not get a reseller plan, then you can decide how much discspace and bandwidth each one are allowed to use, and you can add any domain you want as long you are not going over the space/bandwidth limits.
Why not get a reseller plan, ...
If there was a reseller plan with 300mb/2gb for not much more than the cost of TCH's "starter plan" I would glady take it... These sites are non-commercial, non-profit information sites with very few visits a day. Most contain only a few pages of text. Some are just a favour I am doing for someone. There is no reason, and no one, to pay so much for so little.
