Sarah Posted May 27, 2004 Posted May 27, 2004 Hello all- Was wondering if anyone could help me set up the code in CPanel for a cron job. I want to run a PHP script every Sunday at 4 am. I have no clue how to set this up. Thanks!!! Sarah Quote
TCH-Bruce Posted May 27, 2004 Posted May 27, 2004 If you use the standard mode to create your cron job make the selections as depicted in the image. Be sure to enter the path to your PHP script. Quote
Sarah Posted May 27, 2004 Author Posted May 27, 2004 Now, how about a mySQL database backup each day??? at , say 4 am also?? I know you can manually backup the mySQL database from CPanel, but how do you put it into cron jobs? Maybe this is answered in another thread? Quote
kaseytraeger Posted May 27, 2004 Posted May 27, 2004 OK, this is a bit tangential to the topic at hand, but ... What exactly is a cronjob? I'm sure its some sort of automated tasking procedure, but what'd I'd like to know is what they are typically used for. I'm sure there's stuff I do manually that could be handled via cronjob. Quote
TCH-Bruce Posted May 27, 2004 Posted May 27, 2004 (edited) The definition for cron: The cron command is the clock daemon that executes commands at specified dates and times. Allows execution of commands without user intervention. Similar to the task manager in Windows. Edited May 27, 2004 by TCH-Bruce Quote
TCH-Thomas Posted May 27, 2004 Posted May 27, 2004 This has been asked a thousand times but i dont get it when reading those posts. I have understood (i think) that it would it be possible to set up a cron job to have server do a backup of my site. Lets say my username for server is newbie and i want the backup at 4am servertime, how do i do it? I see Bruce´s picture-example above, but can someone please tell me exactly (kindergarden-level) how i make this php script and what to type in to the command line? Please please please wonderful people Quote
