I'm having troubles getting AWStats to run on my site. The error message I'm getting is below:
Error: Couldn't open config file "awstats.cutsthemeat.com.conf" nor "awstats.conf" after searching in path ".,/home/cutsthe/tmp/awstats/,/etc/opt/awstats,/etc/awstats,/etc,/usr/local/etc/awstats": No such file or directory
- Did you use the correct URL ?
Example: http://localhost/awstats/awstats.pl?config=mysite
Example: http://127.0.0.1/cgi-bin/awstats.pl?config=mysite
- Did you create your config file 'awstats.cutsthemeat.com.conf' ?
If not, you can run "./../../tools/configure.pl"
See AWStats documentation in 'docs' directory for informations on how to setup awstats.
I can't find this "docs" directory. Maybe I'm just missing something stupid? Any help is appreciated.
