For some funny reason the load movie command is not working on my flash movie. The main file loads alright but the second movie fails to load.
It works fine on my hard drive, but fails to work on the server. I Even uploaded the 2 files to a different server and it worked there.
Can someone click on this link for me to see if the second movie loads.
The second movie is simply a small file playing a looped sound.
Very Few Words
Thanks,
I didn't hear anything but the flash Hawaii movie played. Don't know much about flash but there is only one embedded flash file in your HTML page. Don't know if that helps you.
:dance: Welcome to the family, henroo! :dance:
Maybe someone more familiar with flash will be able to help.
Just fixed the problem... the flash movies needed to be in the same directory as the html file they were embedded in. This only applies when you are using the Load Movie command in Flash.
and thanks Bruce for the Warm Welcome,
Merci.
Bye.
