I was having a problem signing into my advanced guestbook to fix some posts. Now I can not connect to the guestbook. I receive the following message:
Warning: mysql_connect(): Access denied for user: 'pseuwmc_agbook1@localhost' (Using password: YES) in /home/pseuwmc/public_html/post/lib/mysql.class.php on line 23
Connection Error
followed by:
MySQL Error : Connection Error
Error Number: 1045 Access denied for user: 'pseuwmc_agbook1@localhost' (Using password: YES)
Date : Sun, February 22, 2004 22:57:46
IP : 65.29.155.243
Browser : Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.1.4322)
Referer : http://www.pseuwm.com/pse/post.html
PHP Version : 4.3.3
OS : Linux
Server : Apache/1.3.29 (Unix) mod_auth_passthrough/1.8 mod_log_bytes/1.2 mod_bwlimited/1.2 PHP/4.3.3 FrontPage/5.0.2.2634 mod_ssl/2.8.16 OpenSSL/0.9.7a
Server Name : www.pseuwm.com
All I wanted to do was administer my guestbook. I have never been able to log in to the guestbook.
Now, I need to clean up the mess I made and then set it up so I can sign into the guestbook in the future.
I know this is long winded, but any help will be appreciated.
Steve
Steve, if you could not login with the default
test and 123 as user and password,
and if adding a user to the guestbook
from cpanel > Manage MySql
and near the bottom you can create a new user,
then just above that, add the new user to the guest book.
(Look near the top to see the name of the guest book
like cpanelname_agbook1
just add the new user to that database)
if all that did not help,
then I think you need to ask support for help
(help desk link at top of page).
Edited by TCH-Don
