Hi
I would appreciate if you could answer the following questions:
1) Your mailing list software. Can one collect emails from a web based form or autocapture form and import them into the software you provide.
2) Your autoresponders. Are they sequential.
3) The Invision board which you provide. I want to place this in a members site within a protected directory. Can this be done.
4) I have mutiple domains on my hosting package at the moment. What package would accomodate up to 10 domains and what would be the cost.
Look forward to your reply
Jeff
1.) Yes, it can collect from a form, if you set up the form to interface with it. It's mailman, which is really good about that.
2.) I believe they are, yes.
3.) Yes you can lock that board down, after installing, just to go web protect in CPanel, and add a password and username file to that directory.
4.) You will need a reseller, and any of them will handle that many. The cheapest is: 19.99 for 8 gigs of bandwidth and 550 megs of space, the most expensive is: 45 for 25 gigs of bandwidth, and 2.5 gigs of space.
You can also set the Invision board to require login to view,
and you can set registration to need admin approval.
Which will limit it to your members,
even if a link to a post is used.
If you need anything else just ask,
our family loves to help :dance:
