Problem With Css And #echo
Guest guest_Peter
I put a css file in my directory and everything works well except background-image: url(images/T03.jpg) and list-style-image : url("gifs/ATBALL4.gif") What is wrong? Also have problem with <!-- #echo var="LAST_MODIFIED" -- > it's not working either.
I tried everything on my local machine and everything works well, but it doesn't on *****' server.
Can anybody help?
  • 3 weeks later...
Peter,
I have been trying to get <!-- #echo var="LAST_MODIFIED" -- > to work also. I will be watching for a solution.
If you find it first, would you share with me? I will do the same for you.
Thanks!
Pat
Pat, your problem is two-fold:
1. Your syntax is NOT entirely correct. There is no space between <!-- and #echo. Here is the correct syntax:
<!--#echo var="last_modified" -->
2. You need to rename your page from using a .htm/.html suffix to a .shtml suffix. The 'echo' command format will only work if the page name is .shtml
For an example, look at: http://tch.kwsupport.com/insertcommands.shtml
HTH,
kw
