theshoppingmama Posted March 22, 2010 Posted March 22, 2010 Hi. This is my first time posting, but I need some serious help. I'm using the Daily Edition Woo Theme and some basic plug ins. However, apparently, the combination is causing problems and I'm spiking the load on the server. (My site has been turned off 3 times for this - not fun.) Have you run into similar problems? Do you know of specific plugins that are problematic? Any advice is much appreciated. Quote
TCH-Bruce Posted March 22, 2010 Posted March 22, 2010 Welcome to the forums theshoppingmama When ever I have problems with plugins I start by turning them off one at a time and see which one it is. If you have a lot of plugins it could take a while to determine which one it is. Since there are thousands of plugins, it would be easier for someone to tell you if they know of specific problems if they knew which ones you are using. Quote
theshoppingmama Posted March 22, 2010 Author Posted March 22, 2010 I'm not sure how to tell if the problem is resolved when I turn off a plug in? Can I do it from my end? It's confusing because last week after updating and disabling some plugins I had no problems. But today they reappeared. Thanks for your help! Quote
TCH-Bruce Posted March 22, 2010 Posted March 22, 2010 If the plugin is causing excessive resource use only one of the techs would be able to tell. Quote
theshoppingmama Posted March 22, 2010 Author Posted March 22, 2010 That's what I was afraid of. Thanks. Quote
