trg Posted July 25, 2009 Posted July 25, 2009 I'm trying to access to my mail from mail2web.com It's says "Error : Login Failure. Please check your email address and re-enter your password." But I'm sure about my e-mail and password. They are correct. I tryed Intellilogin, securelogin login but result is same. In advanced login when I type IP number in "Server name or IP address" works fine. Quote
TCH-Thomas Posted July 25, 2009 Posted July 25, 2009 Welcome to the forum, trg. I have never used mail2web (and can therefor be wrong about this) but if I understand you correct, if it works when you try to log in the advanced way but not in a "default" way, I´d assume it´s something wrong at their end and not your email/password/TCH. Quote
trg Posted July 25, 2009 Author Posted July 25, 2009 (edited) Thanks Thomas, I can't login from "default" way, only from advanced. But not always. This does't work Server name or IP address : mydomain User ID or Login name : myusername (email) Password : mypassword This work fine: Server name or IP address : server ip User ID or Login name : myusername (email) Password : mypassword Any Ideas? Edited July 25, 2009 by trg Quote
trg Posted July 25, 2009 Author Posted July 25, 2009 (edited) Thanks Edited July 25, 2009 by trg Quote
TCH-Bruce Posted July 25, 2009 Posted July 25, 2009 Welcome to the forums trg I have used mail2web in the past but it appears not to be working today. Must be a problem on their end because I have no problems accessing my account using any other method. Quote
trg Posted July 25, 2009 Author Posted July 25, 2009 Thank you Bruce. I'll check again after few days.. Quote
