WxGuy1 Posted February 27, 2009 Share Posted February 27, 2009 (edited) I have an XP machine; I know PHP and some other languages, but I'm not familiar (at all) with VB... I need to monitor a folder for a new file. When a new file appears in that folder, the script will attach it to an email and send it to an address. I've Googled around and found a script that should do something like this... Well, I modified two scripts to do the two things I need it to do (watch a folder for a new file, then attach that file as an attachment and email). Part of a script is copied below - I set it up just to test the email part. > Set objMessage = CreateObject("CDO.Message") objMessage.Subject = "Example CDO Message" objMessage.From = "******@**********.com" objMessage.To = "******@**********.com" objMessage.TextBody = "This is a received fax." objMessage.AddAttachment "c:\Received Faxes\test_received_fax.txt" '==This section provides the configuration information for the remote SMTP server. objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2 'Name or IP of Remote SMTP Server objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "###.##.##.###" 'Type of authentication, NONE, Basic (Base64 encoded), NTLM objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = Basic 'Your UserID on the SMTP server objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendusername") = "******+******.com" 'Your password on the SMTP server objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "*****" 'Server port (typically 25) objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 26 'Use SSL for the connection (False or True) objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = True 'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server) objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60 objMessage.Configuration.Fields.Update '==End remote SMTP server configuration section== objMessage.Send However, when I run that script, I receive the following error: Script: C:\send_email_vbs.vbsLine: 44 Char: 5 Error: The server rejected the sender address. The server response was: 550 Access denied - Invalid HELO name (See RFD281 4.1.1.1) Code: 8004020E Source: (null) Any help? I've tested different ports, Yes or No to SSL, etc, so I'm not sure it's a settings issue (i.e. I think it may be more of a code issue, not a settings issue). Thanks! Edited February 27, 2009 by WxGuy1 Quote Link to comment Share on other sites More sharing options...
WxGuy1 Posted February 27, 2009 Author Share Posted February 27, 2009 Oops -- too late to edit. I've tried a bunch of different ports (i.e. 25, 26, etc). I copy/pasted the above after experimenting a bit, but the problem does not lie in the port number (which has since been set back to 25). Thanks agains! Quote Link to comment Share on other sites More sharing options...
OJB Posted February 27, 2009 Share Posted February 27, 2009 I found this on a google search: http://forums.wirenine.com/f11/550-access-...ello-name-t599/ I am afraid I don't know any VB, so am not sure that is even along the right lines of what you are looking for. Quote Link to comment Share on other sites More sharing options...
WxGuy1 Posted February 27, 2009 Author Share Posted February 27, 2009 I found this on a google search: http://forums.wirenine.com/f11/550-access-...ello-name-t599/ I am afraid I don't know any VB, so am not sure that is even along the right lines of what you are looking for. Thanks for the reply. I think I've found a little utility that will make it a bit easier. Haven't tried it yet, but is sounds like it'll work. OSSMTP, in case any others end up wondering the same. Quote Link to comment Share on other sites More sharing options...
