jeff flowers Posted August 1, 2008 Posted August 1, 2008 Help for the new guy anyone? I recently installed zen cart using fantastico from the file manger. Upon doing so it was installed exactly where I told it but not where I wanted It. When accessing the web address you would see the zen-cart as installed with no mods. I attempted to move the files(in file manager from c-panel) and have inadvertantly moved or renamed the Public.html file. At this point you get a "no webpage found" error when accessing the web address. The question is in short? How do I get my public.html file back? I understand that this is where the www. directs to for my site. But at current really have no content on the site. I have lost no information, But have not been able to locate the file and where I have made it vanish to. keep in mind I am the new guy and still trying to learn the navigation of everything in the c-panel Thanks Jeff Flowers Quote
TCH-Bruce Posted August 1, 2008 Posted August 1, 2008 Put the index.html or index.html file back into the public_html folder. I guess that's what you are asking. You should remove the installation of zen cart and reinstall it to the correct folder instead of moving them. I'm sure there are internal links that would have been created and now they won't be where they should be. I have never used zen cart so I am not certain but most packages that require a database store paths and links in the database. Quote
jeff flowers Posted August 1, 2008 Author Posted August 1, 2008 (edited) Thanks for the welcome Bruce. Have file management back to normal and adress is correct to index. I have already learned alot from the forum, and as always you guys at TCH rock. Thanks Jeff Edited August 1, 2008 by jeff flowers Quote
