If you are using isearch, then please make sure that results that yield more than one page are working properly.
Example, I installed on a client's webste and found that a search for a common term turned up two pages of results. But it jumped right to the last page. I couldn't get it to show me the first page no matter what I did.
If the search turned up just a couple of results that could display on one page, no problem.
So after debugging the son of a gun for hours here's what I came up with:
In isearch/index.php (the heart of the script)
    if(!IsSet($page))
        $page = 1;
Must be changed to
$x = $_GET['page'];
$page = $x;
    if(!IsSet($page))
        $page = 1;
Hope this helps somebody.
Thanks for the tip, I am planning on installing that script on a friend's website, so it will save me some time :)
But why the $x?
Why don't you just do
$page = $_GET['page']; ?
Am I missing something? :o
By the way, have you mentioned this to the script authors?
You are absolutely right... this is what was left over after debugging. Just lazy and didn't rewrite it.
No, I haven't mentioned it to the authors. I'll check out their website and see if I can email them. It looked like I had to sign up for a mailing list... which I really don't wanna do.
