scybermonk Posted November 11, 2006 Posted November 11, 2006 I cannot figure out why I cannot log into my Guestbook. The only thing I can figure is that I have forgotton my password or username. I realllllly do not want to lose everything I have in my guestbook. Help? Quote
TCH-Don Posted November 11, 2006 Posted November 11, 2006 Welcome to the forum scybermonk Carbonize has a password reset script for Lazarus Guestbook that you can use on the Advanced Guestbook. And you might consider converting to his Lazarus Guestbook for better spam protection. It is a rewrite of Advanced Guestbook. And you can keep your database entries as well. Quote
scybermonk Posted November 11, 2006 Author Posted November 11, 2006 And now, my brain is twitching, because apparently, mySQL isn't using the right password either. I am in my Cpanel, looking at "MySQL Account Maintenance". How do I set a mySQL password? *feels like such a damn noob* Quote
TCH-Don Posted November 11, 2006 Posted November 11, 2006 If you mean a set a password for a database user when you add a user in mysql you set a password at the same time. If your guestbook is displaying your guests post correctly then the guestbook is using the correct mysql user/password. you can view it in the guestbook/admin/config.inc.php file. But that is not the same as the guestbook admin log in user and password. For that the reset script will work. Quote
scybermonk Posted November 11, 2006 Author Posted November 11, 2006 I bow to your superior knowledge. In other words, it worked, you rock my socks, thank you so very very much. Quote
scybermonk Posted November 11, 2006 Author Posted November 11, 2006 You wouldn't, by any chance, know how to make a private entry public, would you? Quote
TCH-Don Posted November 11, 2006 Posted November 11, 2006 Glad you are set Did you use the reset script? As to the private entries, I do not use Advanced guestbook. I do know thet in Lazarus Guestbook you can do that in the admin panel. Quote
scybermonk Posted November 11, 2006 Author Posted November 11, 2006 I sure did, and it worked gorgeously. Aha. Hrm. And if I install Lazurus, will I lose any of my current entries? Quote
TCH-Don Posted November 11, 2006 Posted November 11, 2006 No, goto the sites FAQ and forum and take a look. But first in cpanel>backup dowload a copy of the database called agbook1.gz or like that then later if need be you can upload it back in the same place. And copy the guestbook folder to your computer then you can always go back. view the guestbook/admin/config.inc.php file. to get your database config info to put in the new guestbook/admin/config.inc.php file. I just deleted my old forum files and installed Lazarus in the same folder after editing the guestbook/admin/config.inc.php file. and ran the install.php page and selected upgrade. no problem Quote
scybermonk Posted November 11, 2006 Author Posted November 11, 2006 Thanks so much fer all yer help! *runs off to try this* Quote
TCH-Don Posted November 11, 2006 Posted November 11, 2006 If you need more help, the Lazuras forum is very helpful. Quote
scybermonk Posted November 11, 2006 Author Posted November 11, 2006 Couldn't find an opion in Lazurus to switch a messages 'private' or 'public' status. But the straight upload and install swap worked like a charm. Quote
TCH-Don Posted November 11, 2006 Posted November 11, 2006 You are right. I thought you could. Drop by the Lazarus forum and ask if it can be done. Would be a good feature to be added in future versions. Glad the upgrade went ok. Now you have more options including being able to moderate post to cut down spam. Quote
