Dedicated Ip For Ssl
Guest Rob - EnchantedGC
How much is a dedicated IP per year?
Is there a charge for a cPanel to cPanel migration?
I need to move my existing site asap. I already have SSL (with COMODO) and my domains, of course.
Thank you,
Rob
PS - I had a similar problem to one that was mentioned elsewhere in these forums regarding the ticket system. I submitted a ticket to Sales regarding the dedicated IP and I was able to check the status on the site but then 20 min later when trying to check again, was told that the key was incorrect and then the email had no tickets associated with it.
Welcome to the forums Rob :unsure:
The dedicated IP is standard when you have your own SSL certificate. The charge is $35 to install the SSL since you already have one.
There is no charge for a cPanel to cPanel transfer and there should be no problems doing one.
If you have more questions please ask.
Thanks Bruce!
Since my SSL is already installed on my existing site, wouldn't that carry over in the migration or would the cert still need to be manually re-installed?
Thanks again.
