kkashi Posted August 24, 2006 Share Posted August 24, 2006 Hi, How can a user change his password from SquirrelMail? I have assigned initial password from cpanel, but want my client to have ability to change it from webmail. Thanks Quote Link to comment Share on other sites More sharing options...
Madmanmcp Posted August 24, 2006 Share Posted August 24, 2006 You can change it from Webmail. goto the main webmail page, www.******/webmail and there is a "[change password]" link . Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted August 24, 2006 Share Posted August 24, 2006 Bob is correct. There is a plugin for Squirrelmail to do it but it is not available on the shared installation. Quote Link to comment Share on other sites More sharing options...
kkashi Posted August 24, 2006 Author Share Posted August 24, 2006 You can change it from Webmail. goto the main webmail page, www.******/webmail and there is a "[change password]" link . I got to http://www.****.com/sqmail/src/webmail.php, but I don't really see a [change password] link. Thanks Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted August 24, 2006 Share Posted August 24, 2006 The link should be: http://yourTCHdomain.ext/webmail The link to change the password is below the Horde and Squirrelmail options. It is a text link. Quote Link to comment Share on other sites More sharing options...
kkashi Posted August 25, 2006 Author Share Posted August 25, 2006 The link should be: http://yourTCHdomain.ext/webmail The link to change the password is below the Horde and Squirrelmail options. It is a text link. Worked great. Thanks Quote Link to comment Share on other sites More sharing options...
