dazza2006 Posted June 17, 2006 Posted June 17, 2006 Hello from the UK, I am a total novice to the world of OS commerce but I am dipping my toe in the water to design my first on-lone shop, have created a database, and user and added the user to database then click on the one click option to instal oscommerce using cpanel. When i come to log in I am getting the following error: 1146 - Table 'dhinter_osc1.configuration' doesn't exist select configuration_key as cfgKey, configuration_value as cfgValue from configuration [TEP STOP] Any suggestions where i am going wrong much appreciated Cheers Quote
TCH-Thomas Posted June 17, 2006 Posted June 17, 2006 Welcome to the forum, dazza2006. When you use the one click installs, you should not need to set up the databases yourself, cpanel will do this. What I would do is remove any eventual database and folder in the file manager that has been created and then try again. If it then doesn´t work, I think you will need to submit a ticket to the help desk and they will check what might be wrong (link on top of page and in my signature). Quote
dazza2006 Posted June 17, 2006 Author Posted June 17, 2006 Thanks Thomas, will try that and let you know how i get on Cheers Dazza Quote
dazza2006 Posted June 19, 2006 Author Posted June 19, 2006 Thankk you for the warm welcome, do you guys do hosting in the uk, if so how much do you charge, my present provider cannot help with the error i am getting at the moment. I need a hosting company that I can use to host oscommerce style shops, I presently run a small webdesign agency so would be hosting new clients on a on going basis and the need to utilise os commerce is paramount. www.dh-interactive.com cheers Dazza Quote
TCH-Thomas Posted June 19, 2006 Posted June 19, 2006 TCH have a server in the UK. Same price as on the other servers. Open a ticket to the helpdesk and ask if you can be moved to it (or open a new account there if that is the case) if you like. Quote
