I have a website, www.tzitut.com
I'm having a problem here, since it's encoded in UTF-8
When making a simple file, and saving it with UTF-8 encoding, cookie-placement generates an error. (or any other header change)
for instance:
file.php
<?php
setcookie("b","a");
found on link: www.tzitut.com/V2/file.php
generates the following error:
Warning: Cannot modify header information - headers already sent by (output started at /home/***/public_html/V2/file.php:1) in /home/***/public_html/V2/file.php on line 2
when encoding is changed to ANSI, the error disappers.
however, that is not an option, since the website and system is coded in UTF-8.
What do I do?
-Dan.
Edited by TCH-Thomas
Hello and welcome to the forum, Dan. :)
I don´t know the answer to this but hang on, someone will figure it out.
I have removed the cpanel username mentioned in the post for protection.
Welcome to the forum, Dan :w00t:
That error usually happens when you try to use header and
there is a space some where in your code before the header tag
and that counts as output.
