Hi. I created a database for my Gallery2 installation. I forgot the password, but I have an idea what it might be. I had the idea of writing a script connecting to the database. My theory was this if the connection was successful, I remembered the password correctly. I wrote the following script (with actual "Usename" and "Password" inserted):
><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
  "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
<meta http-equiv="content-type" content="text/html; charset=iso-8859-1"/>
<title>Connect to G2 Database</title>
<link rel="stylesheet" href="http://www.hintzefamily.com/test/Just_A_Test/stylescss/stylesheet1e.css" type="text/css" />
</head>
<body>
<?php //Script to connect to G2 Database "Connect to G2 Database
ini_set ('display_errors" 1);
error_reporting (E_ALL & ~E_NOTICE);
if ($dbh=mysql_connect ("localhost", "username", "password")) {
	print "<p>Successfully connected to MySQL.</p>";
	mysql_close();
} else {
	die ("<p>Could not connect to MySQL because: <b>" . mysql_error . "</b></p>");
</body>
</html>
When I attempt to run oit, however, I get the following error:
Parse error: syntax error, unexpected $end in /home/russ/public_html/test/testphp/connect_to_g2..php on line 31
I imagine I am missing something basic. Can anyone take pity on a newbie and point out my error? :-)
In doing some research on the internet I came accross this thread in php Addict which suggests that the error is an indication missing "}", but I seem to have all the curly brackets closed?
This line appears to be the problem:
1) 'display_errors" starts with a single quote and ends with a double quote, and
2) There is a comma missing between display_errors and the 1.
The line should look like this:
>ini_set ("display_errors", 1);
