Reseller Plan Differences
Guest GuestBobGuest
After reviewing the Reseller Plans, it appears the only differences between the Reseller Plans are in the amount of disk space and bandwidth. The only other difference I saw was the dedicated IPs for the Standard and Deluxe Plans.
Are there any other differences between the Reseller Plans?
If you have a Standard or Deluxe plan, custom nameservers are included. Which is nice to make it look like you are hosting sites on your own servers instead of TCH's.
Other than that, as far as I know, disk space and bandwidth.
