TCH-Thomas Posted September 13, 2005 Posted September 13, 2005 I am working on a logo using paint shop pro (version 7.04). The attached image shows one of the letters in this logo. Does anyone know if there is an easy way to make the white line around the letters thicker? Until now I´ve used the stroke and fill function in the styles section of thetext entry dialog box and that box does not seems to have an option to increase the thickness of the line. Quote
TweezerMan Posted September 13, 2005 Posted September 13, 2005 If you don't already have it visible, you need to turn on the 'Tool Options Palette' by clicking 'View', then 'Toolbars', then checking 'Tool Options Palette'. Once you have the 'Tool Options Palette' visible, you can set the line width on the 'A' tab (Text) of the 'Tool Options Palette' window by setting the 'Width' option. Quote
TCH-Thomas Posted September 13, 2005 Author Posted September 13, 2005 Found it. Thanks David. Note to self: Tool Options Palette also works for text. Quote
