If I understand correctly what you're wanting to do, it looks to me like your menu is displaying to the right of your logo because the logo and the menu are in adjacent table cells within the same table row:
<tr>
  <td><center><a href="index.php"><img src="themes/water_drop/images/animalslogo.gif" alt="" border="0" /><br /></a></center></td>
  <td width="100%" align="center">
    <h1></h1>
    <h3></h3><br />
    <span class="topmenu">
I'd suggest putting the logo and menu into separate table rows - ending the table row after the logo with a </tr> tag, and starting a new table row (with a <tr> tag) for your menu:
<tr>
</tr>
<tr>
    <h1></h1>
    <h3></h3><br />
Thanks David. <_>
However, now there´s no menu at all.
Here´s the whole template that I am using (with your changes included as I understood them).
><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html dir="{LANG_DIR}">
<head>
<title>{TITLE}</title>
<meta http-equiv="Content-Type" content="text/html; charset={CHARSET}" />
<meta http-equiv="Pragma" content="no-cache" />
{META}
<link rel="stylesheet" href="themes/water_drop/style.css" />
<script type="text/javascript" src="scripts.js"></script>
 Coppermine version: 1.3.3
 $Source: /cvsroot/coppermine/stable/themes/water_drop/template.html,v $
 $Revision: 1.5 $
 $Author: gaugau $
 $Date: 2005/04/19 03:17:15 $
</head>
<body>
<table border=0 cellpadding=0 cellspacing=0 align="center">
<tr>
</tr>
<tr>
   <h1>{GAL_NAME}</h1>
   <h3>{GAL_DESCRIPTION}</h3><br />
                                       {LANGUAGE_SELECT_FLAGS}<br>{LANGUAGE_SELECT_LIST}
                                       {THEME_SELECT_LIST}
                               </td>
                       </tr>
               </table>
               <img src="images/spacer.gif" width="1" height="15" /><br />
               <table width="100%" border="0" align="center" cellpadding="0" cellspacing="0">
                       <tr>
                               <td align="center" valign="top">
                                       {ADMIN_MENU}
                                       {GALLERY}
                               </td>
                       </tr>
               </table>
       </td>
</tr>
</table>
</body>
</html>
I compared your code to the original theme template.html - you appear to be missing the code for the actual menu. This is what you say your template has:
  <h1>{GAL_NAME}</h1>
  {THEME_SELECT_LIST}
</td>
This is what's in the original template:
  <h1>{GAL_NAME}</h1>
  {MAIN_MENU}<br />
  {THEME_SELECT_LIST}
</td>
Side note: You also should have a closing </span> tag in there somewhere. <_<
Yes. That was one thing I was wondering about but forgot to ask.
In your code above there was a
So I thought you ment that I should replace the
{MAIN_MENU}
with it.
Sorry for the confusion. <_>
Will try the last solution now. <_>
