Not sure where to post this but.
Downloaded a directory script and part of the install directions are:
>) set parameters of your database
1. Database Host. Usually 'localhost'. If not sure contact your hosting provider.
2. Database Socket. Usually '/tmp/mysql.sock'. If not sure contact your hosting provider.
3. Database Port. Usually '3306'. If not sure contact your hosting provider.
2 and 3 I don't have a clue what the settings are on my "local server". I'm using xampp. How can I find out what the socket and port settings are?
This at the time is just for my local server not TCH. Just want to see if it's (the script) worth a darn.
Thanks
Edited by OldTimer
The default port that MySQL servers use is 3306, and the default socket on Linux systems is '/tmp/mysql.sock'. Unless you have reason to believe the MySQL server under XAMPP is not using the default port and socket, I'd suggest trying those settings and see if the script works.
