mystic Posted May 31, 2005 Posted May 31, 2005 Ok i installed agora cart from the cpanel but i can't figure out how to put it on a page of my site. When i sign in into the page it lets me change all the settings and everything but i can't add it to a page of my site. Isn't there a simple HTML code i can use to put it places of my site? On my home page of my new site that i haven't even worked on yet at splaytech.com on the top right hand corner i'd like it to show how full or empty the cart is etc. how may i do all this because after i set everything up i didn't understand how to add it to a page of my site? Quote
TweezerMan Posted June 1, 2005 Posted June 1, 2005 Ok i installed agora cart from the cpanel but i can't figure out how to put it on a page of my site. <{POST_SNAPBACK}> I'm not really familiar with AgoraCart, but it looks to me like you need to set up pages from your site to be in AgoraCart instead of the other way around. It doesn't appear that you can just add snippets of code to regular HTML pages and have them work with Agora Cart. You may want to look at the AgoraCart Overview and the AgoraCart Online Manual for more information. Quote
mystic Posted June 1, 2005 Author Posted June 1, 2005 So you mean pages of my site aren't gonna be really made by my htlm editor, and its gonna be made using agora cart? Quote
TweezerMan Posted June 1, 2005 Posted June 1, 2005 The way I understand it, you can design the look of your pages as a sample page in your HTML editor, but you would then split the sample page into two parts - a custom header and footer template. AgoraCart will display pages with the header and footer templates you designed, and the content generated by AgoraCart will be displayed between the header and footer templates. So to answer your question, yes, AgoraCart is going generate (make) the pages of your web site (at least the ones that will be part of your "store"). Quote
