runmoe99 Posted April 10, 2005 Posted April 10, 2005 Trying to install php nuke 7.5 manually, nned to create a database (which i can do) but the problem lies within needing to run a file called nuke.sql to setup tables within the database. Is this possible? I can't find anything on the subject. Thanks for the help Matt Quote
TCH-Don Posted April 10, 2005 Posted April 10, 2005 Welcome to the forums Matt Normally after you create the database in MySql and add a user you can goto PhMyAdmin, it may be at the bottom of the MySql screen In phpMyAdmin select the database and then on the query page that is a a browse button to locate the nuke.sql file on your computer. This should create the tables. (Note I am doing this from memory so it may not be exact, but you get the idea ) Quote
runmoe99 Posted April 10, 2005 Author Posted April 10, 2005 That is the fastest I have ever been helped on any forum anywhere thank you very much. I was considering the "query" on phpmyadmin but I think I am still a little skiddish with some of this stuff. Again, Thanks Alot for your help, Matt Quote
TCH-Don Posted April 10, 2005 Posted April 10, 2005 You are welcome, I am at work so could not look at cpanel, and I have CRS Quote
TCH-Don Posted April 10, 2005 Posted April 10, 2005 Ok I was wrong, its at the bottom of the SQL tab Location of the textfile: ____________ Browse (Max: 51,200KB) Quote
