Gadianton Posted March 9, 2005 Posted March 9, 2005 I am a fairly advanced programmer, and I for the life of me cannot determine why my window.open statement is not working. Here is the url where its not working: http://www.irietones.com/item/conga+___+tumbadora If you try and click to enlarge any of those rollover images, it's suppose to pop open a new window using the javascript window.open method. For whatever reason, no window opens, and I don't get any javascript errors. I've put in alert statements to verify that it actually hits the right function. All functions are defined in that file so you should be able to just view source and see whats going on. Here is an IDENTICAL implementation of that window.open call, and it works fine here: http://www.wholesalechess.com/chess/giant_...hess+Set+Pieces The two functions being used are identical, so I'm at a complete loss to why ones not working. Could this somehow be a server side issue with TCH? My popup blocker is not the issue either, I've already looked into that. PLEASE HELP ME! I'M GOING INSANE! Quote
TCH-Bruce Posted March 9, 2005 Posted March 9, 2005 The chess page is coded like this: ><a href="javascript:popProductImageByFile('0710_3L.jpg');"><img src="/images/products/0710_3S.jpg" name="three" height=40 border="0" id="three" onmouseover="MM_swapImage('main','','/images/products/0710_3S.jpg',1); document.image_rollover_form.main_large_image.value='0710_3L.jpg';" alt="Click here to see a much larger and detailed image"></a> And the conga page is coded like this: ><a href="javascript:popProductImageByFile('CONL_1L.jpg');"><img src="/images/products/CONL_1S.jpg" name="one" width="33" height="50" border="0" id="one" onmouseover="MM_swapImage('main','','/images/products/CONL_1S.jpg',1)"></a> Not sure if that would cause the window not to diplay or not. Just noticed that the document.image_rollover_form.main_large_image.value was not in the other page. Quote
Gadianton Posted March 9, 2005 Author Posted March 9, 2005 (edited) Ah, the answer always makes so much sense once you find it. After I viewed source and analyzed it some more, I found this piece of code: <script language="JavaScript"> <!-- function SymError() { return true; } window.onerror = SymError; var SymRealWinOpen = window.open; function SymWinOpen(url, name, attributes) { return (new Object()); } window.open = SymWinOpen; //--> </script> I have no idea what its doing, but that was the problem. Thats what happens when you have too many chefs in the kitchen all mucking with the same recipe. Edited March 9, 2005 by Gadianton Quote
