Hello all,
I'm trying to install movable type and I'm running in to errors and I could use some help.
I followed the instructions here
Step 1 --- no problem
Step 2 --- Database name = garetxx_mtdatabase
Database user = garetxx_garetxx
garet has full admin access to database.
Step 3 ---
CGIPath http://www.peterheisey.com/mt/
# DataSource ./db
ObjectDriver DBI::mysql
Database garetxx_mtdatabase
DBUser garetxx_garetxx
# DBHost localhost
I put my password in mt-db-pass.cgi
http://www.peterheisey.com/mt/mt-load.cgi
Gives me this error:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@peterheisey.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.33 Server at www.peterheisey.com Port 80
http://www.peterheisey.com/mt/mt.cgi
Gives me the login screen but when I try to login in get an invalid login.
Anybody have any suggestions it would be much appreciated.
If you need any more information please let me know.
Thanks!
:thumbup1:
You can't login if you haven't done the database thing. Have you checked that you set the permissions on mt-load.cgi to 755? And also, that you uploaded it in ASCII mode? These are the two most common causes of 500 errors.
thanks for the fast reply! I did have to change the permissions to 755 and after I did that I was albe to run mt-load.cgi then it told me to delete me-load.cgi so I did. Thanks!
However I am still not able to log in. Any more good suggestions?
Thanks again!
You're trying to login with Melody / Nelson?
... and are mt.cgi and all other .cgi files set to 755?
I must have missed the memo for Melody and Nelson, because that worked. Thanks for your time and help with this problem. Now I guess i have to figure this software out.
Thanks again.
