EpochsEnd Posted January 30, 2005 Posted January 30, 2005 so I stumbled upon this tutorial for flash. http://www.webwasp.co.uk/tutorials/b15-sou...ound-slider.php Did everything it mentioned, a few times over actually, a couple test swf files and the final one for my band. Then when i implemented it, my main home.swf loaded the soundplayer.swf onto level 8, and nothing worked! I went back to all those test swf files i made from this tutorial, and made a seperate main file that loaded all of those into level 3, 6, 9, whatever. And none of them worked!!! so, everything on this tutorial works, just not when you are loading your swf file into levels other than the main one. (i think at least) CAn someone help? I'm sure the code just needs to be tweaked a little bit... anyone? -Robby Quote
