Do you support XML::Parser? Just curious, as I have a Treo 650 and plan on blogging through mo:blog or hblogger (both Palm Apps), and both these programs need the perl module XML::Parser installed on the back end. I would assume that this is pretty standard stuff, but not for Earthlink, my current host.
Also, you state that I can only host content that I OWN the copyright to. I'm interested in hosting an MP3 blog that specializes in live recordings I make, and I will have permission to host the files before I post them, but the performing artist will own the copyright. Does this fall in the range of permissible activities?
I'll think of other questions soon.
TIA for your answers!
Paul Cooper
We appear to have XML::Parse - it's listed in my perl modules, anyway.
I think if you have his permission, that should be fine. But a staffmember should confirm that. But you can use copyright stuff with permission in almost any medium so it shouldn't be a problem.
