TCH-Thomas Posted September 1, 2004 Posted September 1, 2004 I am trying to setup dada mail for the webring but gets stuck in these... Variable #2: $FILESDada Mail will write many different files when it works with the mailing lists you create. It needs a place on your hosting account to work on these files. This location needs to be spelled out in the $FILES variable. To do this, you need to change the $FILES variable to point to an absolute path to a directory. An absolute path is a path that starts with a '/'. For example: $FILES = '/usr/home/justin/dada_files';To clarify, my home directory is located at: /usr/home/justinIn my home directory, I created a new directory called, dada_files. This is the directory that Dada Mail will use to save it's files in. It's a very good idea to put this directory somewhere other than under your public html directory, as to assure you cannot view the list files from a web browser. Lets say my cpanelusername is thomas and I place these files outside the public_htm, what will $FILES = '/usr/home/justin/dada_files'; look for me then? Then it says Variable #3: $MAILPROGDada Mail needs the location to the sendmail utility to pass emails out to be sent. Most likely, this utility is located at: /usr/sbin/sendmailor: /usr/lib/sendmail You'll most likely only need to change this to a different value in odd server setups. If this is the case, the best idea is to contact the system administrator for the server itself. Do I use /usr/sbin/sendmail or /usr/lib/sendmail And what exactly do I type if name is still thomas? Quote
borfast Posted September 1, 2004 Posted September 1, 2004 Thomas, the $FILES variable will look like this: $FILES = '/home/thomas/dada_files'; About sendmail, you can use /usr/sbin/sendmail Hope this helps Quote
