I got my guest book script running on the main site of my reseller account with just a little tweaking. However, that same basic script is not running on another site on an account that I created.
When I try to run the script on the account I created, I get a 500 error. The error log says:
[Thu Aug 26 08:41:00 2004][error] [client 216.139.37.234] Premature end of script headers: /home/pocketpc/public_html/cgi-bin/svppc-contact.pl
I put in the following simple script as a test and got the same error:
>#!/usr/bin/perl
# Generic form mailing script
# NOTE:  Because this script may be running on a different account than
#        the Web site, it requires FULLY-QUALIFIED URLs.
#Initialize variables
# Write out return HTML page
# Write HTML header
print "Content-type: text/html\n\n";
print "<HTML>\n";
print "<HEAD>\n";
print "<TITLE>Silicon Valley Pocket PC Contact Results</TITLE>\n";
print "</HEAD>\n";
print "<BODY>\n";
print "<H1>Testing script</H1>\n";
# Write HTML end
print "</BODY>\n";
print "</HTML>\n";
Here's the FORM code I'm using to run the script:
><FORM ACTION="http://www.svpocketpc.com/cgi-bin/svppc-contact.pl" METHOD=POST>
I'm probably not pointing to the correct location in the FORM code. The premature end of the script headers probably means that it's trying to run a non-existent script, so what path should I use?
Note that the same guest book script runs fine with that FORM HTML pointing to my ISP, but I'm probably going to be leaving that ISP soon, so I need it running on TCH. I think this is the last major piece to getting my site completely ported to TCH.
Thanks for any help,
Steve
I cut and pasted your code and uploaded it to my server and it worked fine. Did you upload it in ASCII mode and did you change the permissions to 755?
I uploaded it with the same FTP client (FTP Genius) as the script that works. I didn't have .pl files listed as ASCII (I thought I had), but, as indicated, the other script worked fine. I'll try changing it and see what happens, though.
As for CHMOD, I had already changed the file to RWX, R-X, R-X (I knew I forgot to mention something).
UPDATE: OK, it worked now. :lol: One thing that I noticed was that I now have additional script files in the cgi-bin directory. When my guest book script wasn't working, it was the only script file there, but now there are the following files:
  • cgiecho
  • cgiemail
  • entropybanner.cgi
  • randhtml.cgi
I did visit CPanel's CGI Center and execute the simple CGI wrapper script, but that only seemed to create an scgi-bin directory. Does it do something else? (And what is the difference between the cgi-bin directory and the scgi-bin directory?)
But, whatever happened, things seem to be working now. (This isn't the first time mysterious things have happened; one of my pages wasn't showing graphics for some reason, then started showing them again even though I didn't change any HTML near the graphics.)
Steve
