TCH-Thomas Posted August 18, 2004 Posted August 18, 2004 I havent decided yet, but Im thinking about buying a sound card. Right now I have some built in sound with motherboard I think. It doesnt need to be anything fancy, just plain good sound quality and for a wallet that is thin. Anyone have recommendations? Quote
purplespider Posted August 18, 2004 Posted August 18, 2004 If your happy with the sound coming out of your motherboard, I'd stick with it. The latest motherboards have v good on board sound cards, some even with inbuilt 5.1 audio. Which brings me to ask, are you after 5.1, 7.1 audio or just a plain and simple 2 speaker job? James Quote
TCH-Thomas Posted August 18, 2004 Author Posted August 18, 2004 (edited) The latest motherboards have v good on board sound cards...I think mine is from 2001 or something. are you after 5.1, 7.1 audio or just a plain and simple 2 speaker job? 2 speaker job unless someone can convince me why should have more , except for gaming, which I do very little of. Also why I asked this from beginning is that for a long long time the sound in one of the speakers disappears for a few seconds and then coming back. And it keeps doing that. I have my computer connected to the stereo´s amplifier and have done some investigating that it is not either the amplifier (or its speakers) or the cable between the amp and comp that makes it disappear, so I figured with installing a new separate card, the problem will go away. Edited August 18, 2004 by Jikrantz Quote
