IsaacSchlueter Posted June 21, 2004 Posted June 21, 2004 http://isaacschlueter.com >SQL-query : SELECT DISTINCT ID, post_author, post_issue_date, post_mod_date, post_status, post_locale, post_content, post_title, post_urltitle, post_url, post_category, post_autobr, post_flags, post_wordcount, post_comments, post_renderers, post_karma FROM ( evo_posts INNER JOIN evo_postcats ON ID = postcat_post_ID ) INNER JOIN evo_categories ON postcat_cat_ID = cat_ID WHERE 1 AND ( ( post_status = 'private' AND post_author =1 ) OR post_status IN ( 'published', 'protected' ) ) AND post_issue_date <= '2004-06-21 14:18:26' ORDER BY post_issue_date DESC LIMIT 8 MySQL said: #1 - Can't create/write to file '/tmp/#sql_62f1_0.MYI' (Errcode: 30) The Query is valid. Get the same results in phpMyAdmin. Looks like anything and everything MySQL just stopped working. What's up? Quote
Allbuffs Posted June 21, 2004 Posted June 21, 2004 I'm getting the same error. Sent in a help ticket not too long ago. >mySQL query error: SELECT f.*, c.id as cat_id, c.position as cat_position, c.state as cat_state, c.name as cat_name, c.description as cat_desc, c.image, c.url, m.member_name as mod_name, m.member_id as mod_id, m.is_group, m.group_id, m.group_name, m.mid FROM ibf_forums f, ibf_categories c LEFT JOIN ibf_moderators m ON (f.id=m.forum_id) WHERE c.id=f.category ORDER BY c.position, f.position mySQL error: Can't create/write to file '/tmp/#sql_62f1_0.MYI' (Errcode: 30) mySQL error code: Date: Monday 21st of June 2004 05:25:02 PM Quote
IsaacSchlueter Posted June 21, 2004 Author Posted June 21, 2004 Ok, this must be something system-level then. I 777'ed my tmp folder - still got the error. Tried manually creating the file, and 777ing that, too. Same error. Then I made the folder back to 700, and deleted the file. Quote
