Extra Info Required - Simple Reseller Package
Hi, I'm looking at the simple reseller option to house a series of simple websites. When I go to the buy now option I'm a bit confused because the description of the simple reseller package says 75gb bandwith and 3000mb diskspace when the front page says 200gb and 10Gb. Also what does 'I will use My Existing Domain and update My Nameservers only' mean? Many thanks.
What is listed on the plan page 10GB of web space and 200GB of bandwidth is what you will get with the simple reseller plan.
If you currently have a domain name choosing "I will use My Existing Domain" will use that domain name and you will need to change your nameserves to point to the new server your reseller account will be hosted on.
