Sign in to follow this
gaberville
Web Page Load Times.
I'm not sure if this is the correct place to post this, but here goes.
Over the past couple days I have been trying to cut the fat out of my site. I was on a friends dial up connection and vas very unhappy with the load time of my site. So I went in and optimized the logo and completely removed some graphics. I went with a css style nav in favor of the image rollover links I had. It seem a lot faster now.
In general, what is a good load time?
-gabe
Share this post
Link to post
I've always heard 10 seconds as the magic number, meaning that if a page doesn't load in 10 seconds, users are likely to move on to another web site. However, that 10 seconds "rule" may apply only to DSL and cable modem subscribers. I haven't had dial-up in many years, but I seem to remember having more patience when I was on dial-up. So perhaps dial-up customers are accustomed to no more than 20 second load times (?).
Just some food for thought!
Share this post
Link to post
I seem to remember that if they do not see anything for 10 seconds they will move on.
So be sure they have something for them to see right away.
I believe the majority are still on dial-up,
so you may want to get a free dial-up account like netzero
to check on your site now and then.
It can be an eye opener :dance:
Share this post
Link to post
Something to consider is making large images progressive. There are upsides and downsides to doing so, but the upside is that if you've got a big page coming, having some images on progressive will allow the user to have something to look at while the page is loading.
Share this post
Link to post
Well after optimizing all my images and using http compression, I am pretty happy with the results.
Download Times*
Connection Rate Download Time
14.4K ----------28.68 seconds
28.8K----------14.94 seconds
33.6K ----------12.98 seconds
56K----------8.27 seconds
ISDN 128K----3.36 seconds
T1 1.44Mbps---1.39 seconds
If you read this and you are on dial up, please check out my site and let me know if it seem to load quick. --check my sig for the link--
thanks
-gabe
Share this post
Link to post
Gabe,
What http compression software did you use? Although I'm on DSL, your page still loaded much more quickly than others. Plus, it all showed up almost instantaneously (as opposed to parts of it showing up while the rest loads). I'd like to replicate your very quick results on my web pages!
Share this post
Link to post
Thanks Gabe!!! I've bookmarked those pages for future reference. I know they're going to come in handy!!!
:goof:
Share this post
Link to post
Gabe,
I am on a terribly slow dial-up connection and it loaed with lightning speed! YAY
I was reading stats the other day and over 80% of the worlds internet users are on 56K or below connections. Only 16% use DSL/Cable or better. Those are worldwide numbers.
It blew my mind and made me think a lot about my future designs!
Thanks for the link to that program.
Nat
Share this post
Link to post
No problem. I just happened to come across it, applied it to my site and was pleased with the results. So I figured I would pass it on.
Share this post
Link to post
Gabe,
Just wondeirng about that program you used. It says it's for Apache servers... does that mean it only works for those servers or could I use it in general to help the d/l time for the sites I design and maintain?
I have got to trim a lot of fat it seems- my analysis shows slow d/l times for 56k and under.
Nat
Share this post
Link to post
Nat,
Most LINUX servers, those here as well, use Apache. Rest assured that your sites here should have no problem with that.
Gabe, where is a good place to put that script? Header, footer, main page?
Share this post
Link to post
Rob,
Thanks for clearing that up. I knew the servers were LINUX, but wasn't sure if Red Hat was the same as Apache.
I'm kinda unschooled as far as all that goes.
Oh dear, I have SO much to learn! LOL
Merci,
Nat
Share this post
Link to post
Nat,
As long as its installed(it is here) this is the php code you need to add to the top of your page.
><?php
ob_start( 'ob_gzhandler' );
<html>
<head>
</head>
<body>
 <p>This web page is now COMPRESSED!</p>
</body>
</html>
Just add it above your html.^^^the html was added fro reference^^^
-gabe
Share this post
Link to post
Merci,
Nat
Nat,
LINUX is an operating system. Red Hat is just one version of Linux.
Apache is a web server program that runs on Linux and other operating systems.
Jus trying to help. :)
Share this post
Link to post
Merci,
Nat
Nat,
Jus trying to help. ;)
Bruce,
Thanks for schooling me!
I really appreciate that you take time to explain stuff like that because it really is helpful to know.
:D
Nat
Share this post
Link to post
I have been trying to download that compression program, but each of the mirror sites I have tried to access just freezs up my browser.
Anyone know of a reliable download site for this program?
Thanks,
Nat
Share this post
Link to post
Thanks,
Nat
I downloaded it and threw it up on my box, in case it might help:
http://snipe.net/showntell/mod_gzip/mod_gzip-1.3.26.1a.gz
Share this post
Link to post
OK, please don't lash me with a wet noodle for asking such a basic question...
How do I unzip a .gz file? I downloaded the mod_gzip compressed file and wanted to unzip it. I've got WinZip installed on my computer, but I don't know if it works unless the file is compressed using the proprietary .ZIP format. At the very least, it wouldn't open this file.
Anybody want to tutor to a .gz newbie?
Thanks! :)
Share this post
Link to post
do you have shell access?
Share this post
Link to post
Kasey,
Upload the file to your public_html folder and then open File Manager, select the file and select Uncompress from the options.
I did that, and it extracted nothing that I can see. I'm curious as to why Winzip wouldn't open the archive either since I have opened .gz files before. :huh:
Edited by TCH-Bruce
Share this post
Link to post
That php line ure meant to add doens't work for me. http://www.desilva.biz/php/zlib.html says ure meant to have "zlib: fopen wrapper" bit when u call phpinfo() which doesn't appear when I call phpinfo() on my server 34. I've extracted that mod_gzip file but have got all these weird C files what am I doing wrong ?
Share this post
Link to post
Kasey,
Yes I had the same problem with the cpanel extractor there's nothing in that file :S
Share this post
Link to post
Bruce,
There wasn't an option for "uncompress," but there was an option for "extract." I chose this option. As you pointed out, it didn't seem to do anything.
How am I supposed to find out if this will work? Should I just go ahead and put the following code inside a web page and test it out?
><?php
Share this post
Link to post
snipe,
I thought shell access was disable for TCH users because of security reasons. We can ftp into our domain, but from what I was told, we can't telnet.
Does anyone know if this has changed?
Share this post
Link to post
snipe,
The only people with shell access are those on dedicated servers.
Share this post
Link to post
The compression is called Mod-gzip for apache web servers. I cut my download times down by about 80%.
Let me clear a couple things up. Gaberville is NOT using mod_gzip module for Apache, he is using PHP's ability to do gzip compression (http://us3.php.net/manual/en/function.ob-gzhandler.php). People are free to use this as long as it doesn't produce too much load on their shared server (so if you have a high volume site on a shared server, use with caution). If you find zlib support is not enabled in PHP, submit a support ticket to request it be enabled for your server.
Mod_gzip is NOT installed on TCH servers, and won't be because through testing it was found to produce too much load on the CPU's (that info comes from Head Guru Bill).
For those with a dedicated server, to enable mod_gzip for apache if you want try it, all you have to do is select "Update Apache" in your WebHost Manager, make sure mod_gzip is selected in the options, and do a rebuild of Apache. You may have to modify your httpd.conf afterwards to enable full functionality (see the mod_gzip documentation which you can get by downloading a copy of the source code, linked in previous posts). I would only recommend doing this, though if you are comfortable making changes on your server and troubleshooting any problems that might arise.
You can also download and install mod_gzip on a dedicated server manually as Snipe did.
Share this post
Link to post
Wow, I just tried it on one of my pages and got a 66% compression!
Cool :dance:
Share this post
Link to post
Snipe!
Got it! Thanks so much :)
Now just so I don't get into trouble...
Can I use this program here at TCH? I have a regular starter hosting accounts.
Please let me know if this would be OK to use to see if it helps the load times for the sites I have hosted here.
Thanks,
Nat
Share this post
Link to post
Just to be clear if in case my previous post wasn't, mod_gzip is a webserver module that would have to be installed by an admin, but won't be installed by TCH admins on the shared servers because to enable gzip compression on all sites creates too much load (compressing all the pages in real time as they are served uses a lot of CPU). Snipe was able to install it because she has a dedicated server.
You are, however, free to use the PHP method of gzip compression.
Share this post
Link to post
One quick note to those following this thread:
the compression really only affects text. gzip doesn't help graphics, music, and other binary files (unless I am totally mistaken). So its effects are most pronounced on long, text-heavy pages with a few small graphics.
If your page is 35K of text plus 200K of graphics you will go down from 235K total to 215K total or so. A little help, sure, but a relatively small percentage.
You are basically trading processor load on the server and the browser's computer for a reduction in bandwidth/download time.
...dave
Share this post
Link to post
Dave,
That's good to know. I was mostly concerned about getting graphics to load faster... so maybe using this won't help much after all.
Thanks,
Nat
Share this post
Link to post
Your best bet is a graphics program that does all of the fancy stuff related to making graphics smaller. Make sure you use gif or jpg as appropriate because they are both strong but different. Gifs are better for solid sections of color and jpg is better for photo type things where there is little chance of having the same color pixels together in groups.
No matter how much compression you could get on the stream out, you're better off sending smaller images to start with.
Share this post
Link to post
Jim,
I use Fireworks to optimize all my graphics and slice them up. Maybe I am doing all I can to compress already and there is nothing else I can do?
I use the method you stated above... whenever possible I use GIF... I use JPG for photo's mostly and they are compressed at 70 or 80.
Oh well.... maybe there isn't much I can do for some types of layouts.
Thanks for the pointers.
Nat
Share this post
Link to post
Do you use the ability to compress different slices differently? One technique I picked up in a book is to compress fringes more than the middle because in some cases you can get by with it... but it does help to be able to do this in some cases.
Share this post
Link to post
Jim,
Yes I compress slices at different compression rates...
Depending on what the graphic is and how important clear display is... I will play with different formats and compression to see what produces the best visual result with the fastest d/l time.
My load times are not terrible, but I try to always re-evaluate things to see if I can make graphics/pages/text load faster.
Nat
Share this post
Link to post
According to Head Guru (here), mod_gzip was being installed on the shared servers. That ended up getting cancelled, I take it?
Also, from what all I've read, even on high-volume servers mod_gzip creates at worst a nominal increase in load, and can potentially even *reduce* cpu load, depending on filesizes and configuration.
Share this post
Link to post
I just have to add
<?php
above my <html> code and my page is compressed?
No other steps I have to do?
Share this post
Link to post
My load on my website's normal pages is pretty decent, considered I moved to all-JPG images for better clarity...
Every one in awhile I go around and try to find ways to decrease the size and load times...
Share this post
Link to post
To compressed my page I just have to add this over my html code?
<?php
Any things else I have to do?
Share this post
Link to post
Nope, just add that one line of PHP code and you're set! I tried it, and it reduced my page time by 66%. Quite a difference!
Share this post
Link to post
Sorry, I missed your reply. Yes, that was cancelled. I was told by the TCH staff that their actual live testing with it activated for the entire server produced too much load, so the decision was made, at least for now, not to enable it server wide.
Share this post
Link to post
<?php
I added this to my pages and it increased the load time. How do I check to see if this is turned on on server 58?
Share this post
Link to post
<?php
Taken from MikeJ a few posts up;
Share this post
Link to post
Thanks Rob, but I saw that. I guess what I should have asked is how do I know if zlib is supported on my server. Since it does not reduce load times, should I assume that zlib is not supported?
Share this post
Link to post
Use this script on your server:
<?php phpinfo(); ?>
Then look for "ZLib Support" in the output to see if it's enabled or not.
Edited by TCH-MikeJ
Share this post
Link to post
That does mean it is enabled. I do not use that script though so I cant say for sure the exact results "you" should be getting but it is turned on.
Share this post
Link to post
This method only affects text contents,but not grahics?
Beside,Should I change the extension to*.php if using this function?(I don't know php)
Share this post
Link to post
AFAIK, yes only text. You will need to compress your images on your own. This function needs to have the page it is included in have a .php extension. If my page ends in .html and I include that snippet of code I can change the extension to .php and it should work. Dont forget to update your links though.
Share this post
Link to post
Just to put a confirmation to that, yes, it only compresses text. Most images are already compressed, so attempting to compress them further would likely have a negative overall performance effect.
Share this post
Link to post
