alexfung
3 .htaccess Problems
I am new to web programming. And I can't make these options work. Not even make them "work as intended".
<Location /test/alex.txt>
SetHandler application/x-httpd-php
</Location>
gives me a 500 Internal Server Error. Same when without the SetHandler directive. What's wrong with my <location>?
Changing it to Files worked:
<Files alex.txt>
</Files>
but why the original one crashed?
Similarly:
ExpiresActive On
ExpiresByType text/xml A3600
ExpiresByType text/html A300
nearly copied and pasted from apache doc. Placed in .htaccess, any of these lines crashes any file access. Is it because the module is not loaded with the TCH apache?
Finally the XBitHack. I added
XBitHack Full
I traced the http headers and can't see any effect. I turned several .htm files to 654, and then 755. I can't see any Modified tag generated. Why?
Thanks for reading.
Share this post
Link to post
XBitHack Full
Maybe it's a server-level configuration? Frankly I know little about Apache directives (just enough RewriteRule to get by). It would be useful, though, to be able to make some HTML files behave like .shtml. Otherwise I'd need to change filenames and set up redirects.
Update: "XBitHack on" works fine for me (hurray!!). This is a lot better than forcing all .html files to be parsed :tchrocks:
Edited by a__kc
Share this post
Link to post
While I dissagree about the performance hit by parsing all files for SSI or php
Years ago this was an issue with single processors and less ram
but with todays quad 2 gig+ processors and gigabytes of ram
you will be hard pressed to find a performance hit.
So I am not sure its worth the trouble, but I did find this
CHMOD the page files, and only the page files, that you want parsed (i.e. that will contain SSI directives) to 744 (instead of 644). This is what tells the server to parse the page.
Share this post
Link to post
