Dreamweaver 4 Or Mx?
Deverill
Hi folks,
I know several of you have the MX version of DW and wondered if you'd share with me your opinions of whether the upgrade is worth it. I know all the hype they have on the MM site but I want to get the scoop from my family - is it worth it to upgrade?
I only used MX, not MX 2004 but I can tell you that the difference from version 4 (of both Flash and Dreamweaver) is amazing. I know that DW MX 2004 is very directed to standards compatibility, which, in my humble opinion, is of great value.
So if you're using version 4, I'd say yes, it's worth the upgrade! :)
MX 2004 is a lot more friendly when it comes to coding CSS and PHP.
Perfect. Just the reason I needed to upgrade! I'll let y'all (I have a permit to say that word because I grew up in Kentucky! :goof:) know how it turns out for me. Maybe I'll even write a review of sorts for others considering it... but then again, it'll probably be MX2005 before I get around to it :)
