stevevan Posted January 19, 2004 Share Posted January 19, 2004 Due to DNS issues, I tried to remotely log into my cpanel via the link on the help site (here). The remote cpanel site came up, but there was no way to scroll down to access the bottom of the menu. Something missing on the javascript or is it something I'm doing? (or not doing?) Quote Link to comment Share on other sites More sharing options...
Lianna Posted January 20, 2004 Share Posted January 20, 2004 This is being discussed by staff. hang tight. Quote Link to comment Share on other sites More sharing options...
stevevan Posted January 20, 2004 Author Share Posted January 20, 2004 No problem. I didn't know if anyone else was aware of the situation. (Actually, I tho't it was me!) Quote Link to comment Share on other sites More sharing options...
KevinW Posted January 20, 2004 Share Posted January 20, 2004 Steve, not sure what you mean by 'not being able to scroll down' - do you mean you can't see the list of servers? what browser are you using? and screen resolution? Also, I realized that I have not updated the remote login page for all recent servers. I'm at a business conference in Orlando, but if I can fix it today, I will. -kw Quote Link to comment Share on other sites More sharing options...
stevevan Posted January 20, 2004 Author Share Posted January 20, 2004 I can see the list of servers and login prompts just fine. The javascript window opens up and I can expand that, but there are no handles to scroll down to the bottom of the window. It stays at a fixed size. I'm using IE at 1024x768. I'm on my way to Raleigh, NC myself. As I mentioned in an earlier post, it's really no big deal as I'm having domain issues anyway. Just wasn't sure if it was me or something left out of the script. Quote Link to comment Share on other sites More sharing options...
Madmanmcp Posted January 20, 2004 Share Posted January 20, 2004 A temporary fix is to use the arrow keys or page down and page up keys, these should still work. Quote Link to comment Share on other sites More sharing options...
youneverknow Posted January 20, 2004 Share Posted January 20, 2004 It opened a cpanel box that I had to drag open...try holding your mouse to the extreme right and the cursor should turn into a double arrow..hold down the left mouse buttton to drag it to a larger window...it worked for me. youneverknow Quote Link to comment Share on other sites More sharing options...
stevevan Posted January 20, 2004 Author Share Posted January 20, 2004 I have no problem doing opening the window. I can even maximize it. But the problem is how far down the screen can you see? I can't see anything below the "General Server Information" line. Arrow keys and page up/page down won't work, either. Quote Link to comment Share on other sites More sharing options...
