Help With Phpmychat
parrotletmommy
Hi all,
I'm very new to php and am wanting to use the phpMyChat. I have installed and configured everything. But the one problem I'm having I can't seem to figure out how to change the name of the rooms in my Chat. I have the basic Default, My Room 1 and My Room 2. I would like to rename all of these rooms. Could you give me step by step instructions as to how to do this?
Thanks in advance,
Robin :P
Open ..../chat/config/config.lib.php3
Go down about 30 lines and you'll see :
// ------ THESE SETTINGS ALLOW TO FINE TUNE phpMyChat ------
// Proposed (default) rooms and reserved names for private rooms
$DefaultChatRooms = array('Default', 'MyRoom1', 'MyRoom2');
$DefaultPrivateRooms = array('Priv1', 'Priv2');
Change them to whatever you like (no spaces) and save.
  • 3 months later...
I tried the above instructions for customizing phpMyChat. I get the following errors on the login page:
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/localization/languages.lib.php3 on line 70
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 76
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 77
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 78
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 79
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 80
After those errors, I get the login box. If I try to login, all I get are these errors:
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 281
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 457
Warning: Cannot modify header information - headers already sent by (output started at /home/legacyo/public_html/chat/chat/config/config.lib.php3:82) in /home/legacyo/public_html/chat/chat/lib/index.lib.php3 on line 458
Now, the thing does work if I leave "Default", "MyRoom1", and "MyRoom2" alone.
Any ideas?
  • 1 month later...
Is there away to change it so when everyone leaves a convo the convo gets erased so others cant come in l8tr and see what u wer talking about
The closest thing to that I've found is modifying cleaning settings. Go to chat/config/config.lib and change the numbers in this area:
// Cleaning settings for messages and usernames
define("C_MSG_DEL", '24'); <--messages are erased after 24 hours
define("C_USR_DEL", '4'); <--usernames are erased after 4 hours
define("C_REG_DEL", '0'); <---usernames are deleted after (disabled)
This is where I'm stumped though: Does anyone know how to edit the login page so that I can use a background & change the colors?
