Remote_host In .htaccess
alexfung
An example from Apache URL rewrite guide:
RewriteCond %{REMOTE_HOST} ^badhost\.mydomain\.com$
RewriteRule !^http://[^/.]\.****.* - [F]
Nevermind what exactly it is doing. At least it can detect the hostname of the requester. I can't get it work. %{REMOTE_HOST} is always null.
Similary PHP $_SERVER['REMOTE_HOST'] is null.
In php I can revert to gethostbyaddr($_SERVER['REMOTE_ADDR'], what do I do in RewriteCond?
By the way, can I access the rewrite log to ease debugging?
Without knowing exactley the end point your trying to achieve, I am not sure what you want from Remote_Host. The [F] Implies your trying to forbid a user though.
Its not possible to access the Rewrite log. Sorry
Jim
Edited by Jimuni
The [F] just happen to be in the manual example. I wanted to serve some JS files depending on country, and doesn't what to add .js to the list of php processed extensions.
So my intention is:
RewriteCond %{REMOTE_HOST} ^.*\.hk$
RewriteRule (.*)\.js hk$1.js [L]
I quoted the example from the manual just to make sure I don't complicate the issue by making other mistakes unrelated to my inability to access the %{REMOTE_HOST}
