tastewar Posted October 2, 2003 Share Posted October 2, 2003 Something happened with the cpanel update. My default address for my domain had been nOthingsPecial-123+tastewar.com, but this a.m. it was re-set to tastewar. When I attempt to change it back, the plus gets lost, so even though I get this msg back from cPanel: All unrouted e-mail for tastewar.com is now going to nOthingsPecial-123+tastewar.com when I view the config for default addresses, it shows: tastewar.com: nOthingsPecial-123tastewar.com If I use an @ instead of the + it fails with an error: ... does not refer to a valid email account or alias. The default address has been set to the main account. If I don't have the +tastewar.com at all, the update takes, but mail bounces because nOthingsPecial-123 isn't a valid username on server16. How can I get this fixed to how it used to was? --Thanks Quote Link to comment Share on other sites More sharing options...
TCH-Andy Posted October 2, 2003 Share Posted October 2, 2003 tastewar, This is probably related to the issue on server 16 - Server 16 Mailing List Issue. Please follow that thread for updates - If you still have the same issue as that gets solved, then please open a support ticket. Andy Quote Link to comment Share on other sites More sharing options...
tastewar Posted October 3, 2003 Author Share Posted October 3, 2003 I guess you're right! Seems to be working now -- I was able to change the default address for unrouted mail to user@****. Used to be it wouldn't take the @ and you'd have to change it to + but now it seems the reverse. All is well. Or near enough... Quote Link to comment Share on other sites More sharing options...
