docamit 0 Posted September 4, 2003 Share Posted September 4, 2003 This may be a really basic questions but... I (unfortunately) use Frontpage for designing our webpage. I am a beginner and know very basic HTML. I've set up a form at the website but I get an error when I direct it to send the form inputs as an e-mail to me. The error I get is as follows: "The form is being created on a Disk-Based Web or the FrontPage Server Extensions have not been configured to send e-mail. Please direct your system administrator or ISP to the instructions in "Setting up E-mail Options on Windows" or "Setting up E-mail Options on UNIX" in the Server Extensions Resource Kit. If you do not have the Server Extensions Resource Kit, you can find it at http://www.microsoft.com/frontpage/wpp/serk." I've scoured the microsoft website and can't really seem to make sense of what I need to do. Are using forms through Frontpage an option at TCH? I am using Frontpage 2002 SP-2. Thank you in advance for any help. Quote Link to post Share on other sites
chadf 0 Posted September 4, 2003 Share Posted September 4, 2003 I remember seeing this from when I was using Frontpage a few months ago. The error did not effect how my form operated after publishing it to the web. I think the error is just telling you that it won't operate correctly on your home computer since you're not on a server. Try publishing it and see how it works. Quote Link to post Share on other sites
docamit 0 Posted September 5, 2003 Author Share Posted September 5, 2003 chadf, Thank you so much. I published the website (despite the error message) and, what do you know, it worked just fine. Thank you for the suggestion. Quote Link to post Share on other sites
chadf 0 Posted September 5, 2003 Share Posted September 5, 2003 docamit, Hey, that great! I'm glad I could help. It's not very often that I can offer advice - usually it's the other way around! Quote Link to post Share on other sites
