Moodle And Unicode
Paul_Ecuador
Hi:
I'm trying to install moodle in a silver account. The installation runs Ok, but when entering the admin section it says:
unicode - must be installed and enabled
It is required that you store all your data in Unicode format (UTF-8). New installations must be performed into databases that have their default character set as Unicode. If you are upgrading, you should perform the UTF-8 migration process (see the Admin page).
It is possible to solve this issue? I've used moodle in TCH a couple of years back and everything worked Ok.
Thanks for your feedback
