rajah Posted August 19, 2003 Share Posted August 19, 2003 I tried installing Mambo on my website http://www.ryanackerman.com/php/ and can not get it working. I set up the dB like it said.. or at least I think I did. But I am not a php guru, so I really am not gettting very far. Can anyone help? What info should I give? Thanks! Doing a google search of: mambo /classes/database.php on line 25 comes up with a bunch of pages that are having the same problem as me. Quote Link to comment Share on other sites More sharing options...
leezard Posted August 19, 2003 Share Posted August 19, 2003 When you set up the database in cpanel did you also assign a user to it? When you entered the database username and datbase name in the config did you use cpanelname_databasename for DB name and cpanelname_username for username? Quote Link to comment Share on other sites More sharing options...
rajah Posted August 19, 2003 Author Share Posted August 19, 2003 I did setup a user. It appeared that I may have had a wrong password. Doh! {edited out all the useless info} I have it up and running now. Thanks for the help! Thumbs Up Ryan Quote Link to comment Share on other sites More sharing options...
