webgyrl Posted November 23, 2008 Share Posted November 23, 2008 I am just trying to use SpamAssassin and I was wondering where the heck the actual spam box is? I see the "Clear Spam Box" button, but I don't want to press it first without seeing what is in there. Thanks~ Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted November 23, 2008 Share Posted November 23, 2008 According to the description in cPanel: SpamBox will deliver any emails identified as spam by SpamAssassin into a separate mail folder named "spam". This "spam" folder will fill up and should be emptied regularly. So if you check using webmail with your cPanel account you should see a folder called "spam". Or you can just empty it in cPanel itself. I don't use the spam box, I just have the spam automatically deleted. Quote Link to comment Share on other sites More sharing options...
webgyrl Posted November 23, 2008 Author Share Posted November 23, 2008 (edited) According to the description in cPanel: So if you check using webmail with your cPanel account you should see a folder called "spam". Or you can just empty it in cPanel itself. I don't use the spam box, I just have the spam automatically deleted. Hi Bruce!!! I went into cPanel > Webmail and launched Horde... I do not see it in any of the dropdowns. See screenshot. Perhaps I'm not looking in the right place? I wanted to test SA and check what it is catching as spam before setting it to discard email directly. Thanks! NOTE: OK I see if I log in to each account seperately there is a spam box. I thought it would be in the main account box. So it's in each individual account. Edited November 23, 2008 by webgyrl Quote Link to comment Share on other sites More sharing options...
webgyrl Posted November 24, 2008 Author Share Posted November 24, 2008 (edited) Interesting to note that a "spam" box was not created for some of the accounts set up. Is there a reason why this would happen? Edited November 24, 2008 by webgyrl Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted November 24, 2008 Share Posted November 24, 2008 It doesn't get created unless there is spam received. Quote Link to comment Share on other sites More sharing options...
webgyrl Posted November 24, 2008 Author Share Posted November 24, 2008 It doesn't get created unless there is spam received. Thanks Bruce, that's great to know. I appreciate the help, as always! Quote Link to comment Share on other sites More sharing options...
TCH-Carl Posted November 24, 2008 Share Posted November 24, 2008 Another possibility :: After logging into Horde please use "Options" - Then on "Edit options for" -> choose "Mail" --> Server and Folder Information -----> Spam folder: Quote Link to comment Share on other sites More sharing options...
