heavenlydogs Posted August 26, 2008 Share Posted August 26, 2008 Hi, I just rebuilt my site using site spinner. When I am ready to publish it to the web do I need to empty a file or delete something to get rid of my old web site that I built using microsoft office before I publish the new site? Also I have a form and I need to know do you have a "mailto" script, and what the location of it is? Or maybe I should word it what do I enter as the path to the Form script in the 'URL (Action)' field? Thank you for your support, Toni www.heavenlydogs.com Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted August 26, 2008 Share Posted August 26, 2008 The simplest thing to do would be to clean out everything in the public_html folder before publishing your new site. If you are using "mailto" to collect information from a form it's usually coded something like this: ><form action="mailto:youremail.com" method="post" enctype="text/plain"> Check out this sample from W3Schools. Quote Link to comment Share on other sites More sharing options...
heavenlydogs Posted September 15, 2008 Author Share Posted September 15, 2008 The simplest thing to do would be to clean out everything in the public_html folder before publishing your new site. Hi, Thank you for your reply. Can you please advice how do I "clean out the public_html folder"? Thank you for your help. Toni Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted September 15, 2008 Share Posted September 15, 2008 The easiest way would be to ask the helpdesk to clean out everything inside the public_html directory. Note: you need to tell you do not want to have email cleaned etc only the public_html. Otherwise if you want to control what is being deleted from the public_html you could yourself by using either cpanels file manager or do it through a ftp program. No matter which way you choose, make sure you have a fresh backup of whats stored in your account (see "Select Partial Backup" in the the backup wizard in cpanel). Quote Link to comment Share on other sites More sharing options...
